If you deleted a flow which you want to use again, you can restore the flow by the following:
- Click on your username initials on the top right corner of the page to open a menu. Click on “Change Log” as highlighted in the below image.
- The change log for the organization will appear. Click on the Restore button in the Action column of the flow that you want to restore as illustrated in the below image. eg. calc test
- Once the flow gets restored, the message in the below image will appear and the flow will appear in the solution it was deleted from.
