The below are some utils methods that can be used in a Calculator step.
Datatype conversion
You can convert a value to a different datatype:
let newValue = utils.convert(val, toType, format);
Objects
You can copy an object:
let newObj = utils.copy(obj);
You can hash an object with an algorithm:
let HashObj = utils.crypto.createHash(algorithm, options);
You can create an HMAC for an object:
let HmacObj = utils.crypto.createHmac(algorithm, key, options);
You can create a cryptographically artificial random data with the byte size:
let RandomData = utils.crypto.randomBytes(size);
You can merge a source object to a destination object:
let MergeObj = utils.merge(a, b, options);
Schemas:
You can generate a schema from a JSON object:
let newSchema = utils.schema.generateSchemaFromJSON(obj);
You can flatten a schema:
let newSchema = utils.schema.flattenSchema(schema, options);
You can validate a schema in a document:
let validateSchema = utils.schema.validate(document, schema, coerce, showAllErrors);
You can merge schemas:
let mergeSchema = utils.schema.mergeSchemas(schemas);
Escape XML Entities
You can escape XML entities by replacing them:
let safeXML= utils.escapeXml(xmlString);
Exclude Empty Arrays:
return Object.entries(input.record.fieldName).length = 0
Convert runDate to an epoch time:
input.parameters.fromDate = utils.dayjs(input.runInfo.lastRun).valueOf()
