Hardware requirements for on-premise servers/ relays
The following are the minimum hardware requirements for on-premise servers:
Windows Server:
The following requirements assume that Synatic and all essential services will run on a Windows Server:
  • CPU: An Intel processor with VT-x.
  • CPU Core Count: At least 8 cores.
  • Memory: At least 16GB of RAM.
  • Storage: At least 60GB of solid state disk storage.
  • OS: Windows Server 2012 +
Linux Server:
The following minimum requirements assume that Synatic and all essential services will run on a Linux Server:
NB: Depending on expected system usage these requirements many increase.
MongoDB (on-premise):
It is highly recommended that the MongoDB database runs on its own separate server on-premise or on MongoDB Atlas (hosted). For the most reliable and robust configuration we recommend setting up a 3 node replica set with the following minimum specifications for each node:
  • CPU Core Count: At least 2 cores.
  • Memory: At least 8GB of RAM.
  • Storage: At least 20GB of solid state disk storage.
If you require an on-premise installation, please contact us via our contact page which is in the link below:
https://www.synatic.com/contact/message-us
Relays
