Illustrated below is an example of a flow where the Record Generator is the source step.
The below page is the dataset which contains fields that have null values.
To remove the fields that have null values in the dataset, the code in the image below is used in a Calculator step.
Copy and paste the below code in the Calculator step:
for(const key in inputRecord){
if (!inputRecord.hasOwnProperty(key)) continue;
if(!inputRecord[key]){
delete inputRecord[key];
Illustrated below is the output results after the above code is added in the Calculator step.
