- Add a Schedule step to the Trigger box in your flow as shown below.
- To customize the schedule to run every 2 hours, select “Day” and select every 2nd hour. To select multiple hours, press Ctrl and click on the number as shown below.
Highlighted in the above image are the hours that you selected.
