To copy a flow to a different solution, follow the instructions below:
NB: Please note that if there is a component in the flow (connection, parameter, relay or buffer), it has to be created on the different solution for the flow to work.
- Click on the 3 dots circled in red next to the flow you want to copy and then click on “Copy Flow” underlined in red as illustrated below. In this example, the solution name is called “Testing”.
- The below page will appear. You can edit the flow name if required. Click on the highlighted expander icon to select the solution you want to copy the flow in. Once the solution name is selected (eg. Global), click on the Copy button.
- The copied flow will open in a new tab and the flow is copied to the selected solution as shown in the below image.
