The following are the new features for July 2022 :
Import flow feature:
It is now possible to import a flow from one organization to another by using the Import Flow feature! The flow’s components can be created or selected when importing the flow. Click on the below link to find out more on how to use this feature:
Copy flow feature:
Copying a flow from one solution to another solution in an organization is now available by using the Copy Flow feature! The flow’s components will have to be created in the new solution and selected in the relevant steps after the flow is copied. The below link is an example of how to copy a flow to a different solution:
