If you ever need to filter within Buffers you can use the Filter feature available within the buffer.
A typical example for this is if you want to find a specific record, or a set of records or merely want to order by a certain field.
To do this, navigate to your Buffer and click on the Values button listed at the top.
You should be presented with all the records within your buffer. From here, you can merely click the Filter button, and add a rule to filter out the data you are looking for. You can also Order (sort) by a specific field within your results. Thereafter, click “Query Values”.
