If you require to use the Azure Blob Storage connection, please follow the instructions below:
- Retrieve the Storage Account name and Container name from your Azure account as outlined in the image below.
- Retrieve the Storage Access Key from your Azure account as per the image below.
- Set up the connection with the credentials from instructions 1 and 2 as illustrated in the image below. Click on the Save button and then click on the Test button to test if you have a successful connection.
NB: Please note that the path in the Path field in the step does not need to contain the domain path for the URL and it’s only the endpoint path that needs to be referenced as per the image below.
