How do I like up the name and solution for a flow by its id?
Hi there,
Unfortunately at this stage it is currently not possible to identify a Solution and flow name from a flowId. We will add a feature for this.
In the interim, if you are able to ascertain the solutionID then you can navigate to the flow in question by entering the following URL while logged into the org:
https://admin.synatic.com/app/admin/solutions/{solutionId}/flows/{flowId}/edit
Kind regards
Matt
