The following are the new features for August 2024:
AMS360 Data Lake Connector
An AMS360 Data Lake Connection is now available! The page below shows the required credentials in order to create a connection. The Grant Type is filled out by default. Provide the Client ID and Client Secret. Once the credentials are inputted, you can click on save and test the connection by clicking on the Test button.
Click on the link below to access the AMS360 Data Lake API reference document:
AMS360 Data Lake API Reference Document
AMS360 Data Lake Source Step
We now have an AMS360 Data Lake Source Step! It is used to get records from AMS360 Data Lake. This step requires an AMS360 Data Lake connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the highlighted button to create a new connection. Provide the API excluding the base path. Select the HTTP Method. The Get method is selected in the image below.
AMS360 Data Lake Lookup Mapper Step
We now have an AMS360 Data Lake Lookup Step! It is used to map AMS360 Data Lake records. This step requires an AMS360 Data Lake connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the button highlighted in yellow to create a new connection. Provide the API excluding the base path. Select the HTTP Method. The Get method is selected in the image below. Click on the plus button highlighted in blue to map the records.
Sagitta SOAP Connector
A Sagitta SOAP Connection is now available! The page below shows the required credentials in order to create a connection. The red asterisks next to the fields show that those fields are required. The Grant Type is filled out by default. Provide the WSDL URL and the Account name. where. Once the credentials are inputted, you can click on save and test the connection by clicking on the Test button.
Sagitta SOAP Source Step
A Sagitta SOAP Source Step, which is used to get records from the Vertafore Sagitta SOAP API, is now available! This step requires a Sagitta SOAP connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the highlighted button to create a new connection. Type the body of the SOAP request in JSON or XML format.
Sagitta SOAP Lookup Mapper Step
We now have an AMS360 Data Lake Lookup Step! It is used to look up records from the Vertafore Sagitta SOAP API and map them onto records. Provide the API operation to execute in the Command field. Type the body of the SOAP request in JSON or XML format. Click on the plus button highlighted in blue to map the records. This step requires a Sagitta SOAP connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the button highlighted in yellow to create a new connection.
Sagitta SOAP Destination Step
We have a new Sagitta SOAP Destination Step that is now available! It is used to send records to the Vertafore Sagitta SOAP API. This step requires a Sagitta SOAP connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the highlighted button to create a new connection. Type the body of the SOAP request in JSON or XML format.
Salesforce Bulk V2 Destination Step – Result Delay Field
The Salesforce Bulk V2 Destination Step now has a Result Delay field shown in the image below. This is used to set the amount of time to wait in milliseconds before retrieving results. This is useful when retrieving a lot of records.
HTTP Authentication Connection – Oracle Symphony Auth Type
An Oracle Symphony Auth Type is now available in the HTTP Authentication Connection Auth Type list. Click on the dropdown as shown to select it from the options.
