The following are the new features for May 2024:
Flow Triggers - Change Log
The Flow Triggers now have a Change Log Tab. Click on the Change Log tab to access the trigger’s change history. There are fields that show the disabled and attached state of the trigger as highlighted in the image below.
REST API Builder - Rate Limit
There is a new Rate Limit feature available in the REST API Builder! This is used to create a custom rate limit for REST services by configuring how many requests are allowed in a 10-second timeframe. Click on the Enabled checkbox to set the maximum rate limit as shown in the image below.
Open PGP Mapper Step – Decrypt Mode Config Section
The Open PGP Mapper Step now has a config section in the Decrypt Mode available.
The Open PGP Mapper step is used to encrypt or decrypt data according to the Open PGP standard. This step requires an Open PGP connection to work. Click on the highlighted button in the image below to create a new connection.
Select whether to Decrypt or Encrypt from in the Mode section. Select whether to use Binary or Armored encryption. These two sections are required for the step to work.
The Config Section can only be used if the Decrypt Mode is selected. Click on the checkbox to allow insecure decryption with signing keys.
Azure Data Lake Storage Destination Step
We now have an Azure Data Lake Storage Destination Step available. It is used to write files to Azure Data Lake Storage. This step requires an Azure connection to work. Click the highlighted button in the image below to create a new connection. The Path field is required for the step to work.
