The following are the new features for September 2024:
Amazon S3 Bucket Destination Step– Content Type Field
The Amazon S3 Bucket Destination Step now has a Content Type Field! This is used to determine the content type that the object should be stored as. It is set to application/octet-stream content type by default as shown in the image below. This can be replaced by the required content type in the field.
Box Actions Destination Step – Creating a Folder Action
The Box Actions Destination Step now allows you to create a folder as an action. Click on the dropdown arrow as shown in the image below to select the Create Folder Action.
Once the Create Folder Action is selected, the fields shown in the image below will appear. Provide the Parent Folder ID to create a folder from in the field shown in the image below. After that, type in the Name you want to give to the new folder in the field.
Applied Epic SDK SOAP Destination Step – Additional Namespaces
Namespaces can now be added to the Applied Epic SDK SOAP Destination Step! This is used to add namespaces that will be included in the XML tag of the main operation. Click on the Add Item button to add a Name Space as shown in the image below.
Provide the Name and Value in the respective fields as shown in the image below. To delete a namespace, click on the highlighted trashcan icon.
HTTP Service Step Source Step – Path Separator
The HTTP Service Step Source Step now has a Path Separator field in the Check Field and Field URL Paging section. The Paging checkbox should be checked to access the fields.
This will help ability to select JSON object path separators to help avoid errors when your property names contain the characters highlighted in the image below.
For more information on the HTTP Service Step Source Step - Paging Options, click on the link below:
