New features for April 2022
The following are the new features for April 2022:
Oracle NetSuite SuiteTalk Connection:
A connection to Oracle NetSuite SuiteTalk is now availabe! Click on the below link to find out more.
How to use the Oracle NetSuite SuiteTalk connection
ACORD OCR destination step:
This step converts an ACORD form to a JSON format. Click on the below link to see how this can be done.
How to extract records from an ACORD form to a JSON format
Parse Address mapper step:
This step can break down any street address into it’s components parts. Click on the below link to view an example.
How to parse a street address
Log Input feature:
This feature allows you to download a JSON file of the data in a primary flow. It is a helpful feature for debugging. Click on the below link to see how this can be done.
How to log a primary/ main flow's data in a secondary flow
Byte Group step:
The step allows you to convert a file to a Base64 string and a Base64 string to a file in bytes. Click on the below link to see how it can be used.
How to convert a file to a Base64 string from an email trigger
NB: Stalled flows will now automatically be cancelled within an hour.
