It takes a standard ACORD PDF and uses it to extract records from an ACORD PDF form to a JSON format.
NB: All data processing is currently conducted in the US region, subject to change.
Illustrated in the below image, a pass through step is used as a reader source step.
The below image is how the ACORD OCR destination step looks. In the “From Field”, it can return all the fields by default if it’s left blank or it can return a specific field if specified.
