If you require to export specific records from a run, please follow the below instructions:
NB: Please ensure that the records you require to export (completed, errors or skipped) is being logged using the Log Record Error RecordEvent step at the end of the flow.
Illustrated in the image below is the run history of the flow. Click on the required run by clicking on the date as highlighted in the below image.
The below page will appear. Click on the required logged records that you want to export. In this example, we are exporting a few error records.
Illustrated in the below image are the records that have errors. Select the required records by clicking in the check box on the left of the page and then click on the highlighted Export button. A JSON file will download with the records and the errors the records encountered while processing in the run.
