The following are the new features for December 2024:
ACORD OCR Destination Step - Flatten PDF checkbox
ACORD OCR Destination Step now has a Flatten PDF checkbox option. It is used to flatten the pdf document and remove editability. The pdf would be converted to an image-based pdf if the checkbox is selected. This is useful for increasing OCR reading accuracy.
PostgreSQL Bulk Insert Destination Step
PostgreSQL now has a Bulk Insert Destination Step available! It is used to insert records to PostgreSQL in bulk. This step requires an Applied Epic connection to work. Click on the dropdown arrow in the image below to select a connection. Alternatively, click on the highlighted button to create a new connection.
Ops Portal Filtering
The Operations Portal now has an Options button which can be used to select the to either accept, reject or clear records.
In addition, there is an option to bulk edit fields by entering a value which will edit all records or the filtered ones. Hover the mouse on a field to access this option and click on the edit button as shown in the image below.
For more information on this Filter option, click on the link below:
