New Features for January 2026
Compliments of the New Year Synaticals! :partying_face:
We have exciting new features that are in the pipeline for 2026! We love sharing them with you and look for ways to improve our product to cater to your needs consistently. Looking forward to another fantastic year with you!
The following are the new features for January 2026:
Salesforce Bulk API 2.0 Source Step
A Salesforce Bulk API 2.0 Source step is now available! It is used to query records using the Salesforce Bulk API 2.0. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
Salesforce Bulk API 2.0 Destination Step
In addition, a Salesforce Bulk API 2.0 Destination step is available! It is used to send records to Salesforce using the Bulk API 2.0. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
HubSpot File Uploader Destination Step
A HubSpot File Uploader Destination step is available. It is used to upload files to HubSpot. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
Snowflake Connection – Key Pair Authentication Method
The Snowflake Connection now has Key Pair as an Authentication Method when setting up a connection. Click on it to access the credential fields.
Source and Mapper Queries – Object View
The Source and Mapper Queries tools now have an Object view.
