The following are the new features for June 2026:
BenefitPoint Source Step
The BenefitPoint Source step is now available! It is used to retrieve records from BenefitPoint. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
BenefitPoint Lookup Step
There is also a BenefitPoint Lookup step available! It is used to look up records from BenefitPoint. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
BenefitPoint Destination Step
In addition, a BenefitPoint Destination step is available! It is used to store records in BenefitPoint. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
My Files Changes to Snippets
My Files is now Snippets. This is still located in the Menu Bar. Use it to store files in your Org.
Applied Epic REST
The Sage Intacct REST Source step is now available! It is used to retrieve records from the Retrieve records from the Sage Intacct REST API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. There is a default HTTP Route that is provided in the field. Provide one to use if this default one is not preferred.
