The following are the new features for June 2025:
AMS360 File Upload Step
The AMS360 File Upload step is now available! It is used to upload a file to AMS360. A connection is required for this step to work.
Debug Function on Benefitpoint and Big Query Steps
The Benefitpoint and Big Query Steps now have a debug function which logs Raw XML, so you can see the request after a debug. Click on the checkbox to enable the debug function.
Validation Errors Section
There is now a Validation Error section at the bottom of the page. This happens whenever a flow is validated and errors are flagged on a step. The error will be shown and the step outlined as illustrated in the image below. There are also buttons that can be used to move across the different errors.
Buffer Query Steps – Optimization Options
There are now new optimization options in the Buffer Query steps. These can be used to query in the steps. Click on the checkbox to select the required option.
Unsaved Changes Notification
There is now an Unsaved Changes notification that is used to alert of changes made to a step.
