The following are the new features for August 2025:
AMS360 oData Source Step
The AMS360 oData Source step is now available! It is used to retrieve records from AMS360 using the oData API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
AMS360 oData Destination Step
In addition, an AMS360 oData Destination step is available! It is used to send records from AMS360 using the oData API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
File Stash
The File Stash function has been added to the Menu Bar! It is used for file storage in Synatic within Orgs. Click on the Upload button to upload files. Alternatively, drag and drop files to upload them. Folders can also be created to help manage the files. Details of each file, such as name, file type, size, and date, will be shown. Click on a file to get options to copy, delete, or download the file.
EJSON - Object View
There is an EJSON view when testing a step. It provides the data type details after testing a step. Click on the EJSON button to get detailed datatypes.
Synatic FileStash Source Step
A Synatic FileStash Source step is now available! It is used to retrieve files from Synatic’s file stash. Provide the file name in the field to retrieve the required file.
Synatic FileStash Destination Step
Additionally, a Synatic FileStash Destination step is now available. It is used to store files in Synatic’s FileStash. Provide the full path to store the file.
Synatic FileStash Action Step
A Synatic FileStash Action Destination step is also available! It is used to perform actions on FileStash files. Select the action to perform (Delete File, Move File or Copy File) and complete the required fields.
