The following are the new features for July 2025:
AMS360 EMS Source Step
The AMS360 EMS Source step is now available! It is used to retrieve records from AMS360 EMS. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
AMS360 EMS Lookup Step
There is also an AMS360 EMS Lookup step available! It is used to look up records from AMS360 EMS. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
AMS360 EMS Destination Step
In addition, an AMS360 EMS Destination step is available! It is used to update records in AMS360 EMS. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
NowCerts Source Step
A NowCerts Source step is now available! It is used to extract data from the NowCerts agency management system. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
NowCerts Lookup Step
There is also a NowCerts Lookup step available! It is used to query data from the NowCerts agency management system and adds the result to a record. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
NowCerts Destination Step
In addition, a NowCerts Destination step is available! It is used to write, update or delete data from the NowCerts agency management system. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
Google API Source Step
The Google API Source step is now available! It is used to retrieve data from a Google API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
Google API Lookup Step
There is also a Google API Lookup step available! It is used to look up data from a Google API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
Google API Destination Step
In addition, a Google API Destination step is available! It is used to update data in a Google API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
Sage Intacct REST Source Step
The Sage Intacct REST Source step is now available! It is used to retrieve records from the Retrieve records from the Sage Intacct REST API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. There is a default HTTP Route that is provided in the field. Provide one to use if this default one is not preferred.
Sage Intacct REST Lookup Step
There is also a Sage Intacct REST Lookup step available! It is used to look up records from the Sage Intacct REST API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. Provide an API route in the field that should be used.
Sage Intacct REST Destination Step
In addition, a Sage Intacct REST Destination step is available! It is used to send records to the Sage Intacct REST API. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists. There is a default Route that is provided in the field. Provide one to use if this default one is not preferred.
