The following are the new features for April 2026:
SAS File Reader Step
An SAS File Reader step is now available! It is used as a parser for SAS files. No configurations are required in the step itself.
Email – Multiple Attachments Destination Step
In addition to the existing Email Destination step, there is now an Email – Multiple Attachments Destination Step available! It is used to send an email with support for multiple attachments. Click on the Add Row button in the Attachments section to add multiple attachments.
SendGrid Mail Destination Step
A SendGrid Mail Destination Step is also available! It is used to send an email via SendGrid. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
SendGrid Template Destination Step
In addition, there is a SendGrid Template Destination Step. It is used to send a SendGrid template e-mail. A connection is required for this step to work. Click on the Plus button to create a new connection. Alternatively, select one to use if one exists.
Buffer Query Tool
A buffer query tool is now available. This is used to query all buffers. Click on the Tools menu (1) and then click on the Buffer Query to open. Select a buffer to query and click on the Query button.
