Compliments of the New Year Synaticals!
We have exciting new features that are in the pipeline for 2025! We love sharing them with you and look for ways to improve our product to cater to your needs consistently. Looking forward to another fantastic year with you!
The following are the new features for January 2025:
Encryption and Decryption Destination Steps
We now have an Encryption Destination Step that is used to encrypt the output data. This step requires a connection to work. Click on the highlighted button in the image below to create a new connection.
The encryption keys are set on the connection. Take note that the Encryption and Decryption steps use the same connection. One connection can be created for both steps.
Click the links below for more information on the steps and connection:
Datadog Log Destination Step
A Datadog Log Destination step is now available! It is used to send a log to a Datadog platform The configuration is shown in the image below. This step requires a connection to work. Click on the highlighted button in the image below to create a new connection. Type the log message in the Message field for the step to work.
Datadog Run Event Step
There is also a Datadog Run Event step available which sends a log to a Datadog platform. This step requires a connection to work. Click on the highlighted button in the image below to create a new connection. Click on a checkbox to select an Event(s).
Buffer Single Destination Step
We now have a Buffer Single Destination step available. This is used to send records to a Buffer one at a time. A buffer is required for this step. Click on the dropdown to select a buffer or click on the highlighted button to create a buffer. Select the Operation to perform from the options.
WorkBook Connection - API Key
The WorkBook Connection now has an API key as a connection type. Select it from the options as shown in the image below.
