The tabs feature allows you to open multiple windows of flows/ connections/ buffers/ relays/ API builders/ operations views as tabs in the system.
The tabs feature also allows you to come back to the tabs you had opened if you log out and log back in the system. It saves the current tabs that you left opened before logging out.
NB: The number of tabs available is limited by the size of your window.
The below image is an example of multiple flows being opened in different tabs.
To close a tab click on the highlighted close icon as shown in the image below.
