The following are the new features for March 2025:
SFTP List Step – File Size in the Test Result
The SFTP List step now shows the file size in the test result. The size is in bytes as shown in the image below:Calculator Step – Validation when Testing
Note: As of 28 March 2025, all Calculator code will be subject to strict validation when Testing To Step. All Flow tests will result in an error on the Calculator step if there are errors in the code, regardless of when the Flow was created. The Flow will still execute without the validation.
Inspect the error output of the step to see information on any code errors, including a line number directing you to the location of the error. Alternatively, click the Validate button to find errors in your code before saving.
