The following are the new features for November 2024:
REST Service – Multiplatform Data
The REST service now has Multipart Form as an input content type. It is used to extract multipart form data from a source in the flow. It will extract the data even though the Multipart Form Source step has not been added to the flow. To select this option, create a new path (1) and select the POST Option (2) as shown in the image below. From there, select the Source section and the Input Content Type field (3) will be displayed where you can select Multipart Form from the option from the list (4).
Ops Portal – Filtering
The Operations Portal now has a filter as a view option. This is used to filter the records. The image below shows the filter option.
For more information on this Filter option, click on the link below:
Relays V3 – Enable Checkbox
Relay V3 is now available! There is a checkbox option when creating a new relay that will enable the new relay version. Select this box to enable Relay V3.
For more information on installing Relays, click on the links below:
