New Features for February 2026
The following are the new features for February 2026:
HawkSoft Connector
A HawkSoft connection is now available! The page below shows the required credentials to create a connection. Provide a suitable connection name and then fill in the fields. The red asterisks next to the fields show that those fields are required. Once the credentials are provided, click the Save button.
File Stash – File Preview
The File Stash and Run File Destination Step now has a File Preview button. This can be used to preview files that are in the step. Click on the eye icon to preview a file.
The Run File Destination Step now also has a File Preview button. This can be used to preview files that are in the step. For the Run File Destination step, however, the Run must be executed first; then the file can be previewed in the Run Result. Click on the eye icon to preview a file.
PDF Writer Step – Single-Page Checkbox
The PDF Writer Step Now has a single-page checkbox. This is used to generate a PDF as a single page. Scroll down to the Page section in the PDF Writer step to access the checkbox.
Window Tab - Position Change Button
You can now change the position of the window tab. This button is located at the top right corner in the tabs section. Click on the window tab button to change to vertical or horizontal tabs.
Australia Node
Synatic now has an Australia node available! This makes it possible to set up Orgs in the Australia region.
